Time Before: 0.01454 seconds
Time After: 0.01900 seconds
Time Taken: 0.00445 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.01911 seconds
Time After: 0.01956 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.01979 seconds
Time After: 0.01992 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.02083 seconds
Time After: 0.02299 seconds
Time Taken: 0.00217 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.01999 seconds
Time After: 0.02715 seconds
Time Taken: 0.00716 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.03332 seconds
Time After: 0.03376 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.03614 seconds
Time After: 0.03740 seconds
Memory Before: 2,148.281 KB
Memory After: 2,148.141 KB
Time Before: 0.03274 seconds
Time After: 0.03760 seconds
Time Taken: 0.00486 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.164 KB
Time Before: 0.06210 seconds
Time After: 0.06225 seconds
Memory Before: 2,814.719 KB
Memory After: 2,815.234 KB
Time Before: 0.07361 seconds
Time After: 0.07499 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,903.047 KB
Memory After: 2,903.641 KB
End call of global.php: 0.077421903610229
Time Before: 0.08243 seconds
Time After: 0.08260 seconds
Memory Before: 3,539.773 KB
Memory After: 3,540.203 KB
Time Before: 0.08487 seconds
Time After: 0.08651 seconds
Time Taken: 0.00164 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=101727'
Time Before: 0.10371 seconds
Time After: 0.10396 seconds
Memory Before: 4,294.930 KB
Memory After: 4,295.172 KB
Page generated in 0.10261201858521 seconds with 9 queries, spending 0.0080287456512451 doing MySQL queries and 0.09458327293396 doing PHP things.
