Time Before: 0.02387 seconds
Time After: 0.03123 seconds
Time Taken: 0.00736 seconds
Time Before: 0.03135 seconds
Time After: 0.03183 seconds
Time Before: 0.03208 seconds
Time After: 0.03222 seconds
Time Before: 0.03311 seconds
Time After: 0.03580 seconds
Time Taken: 0.00269 seconds
Time Before: 0.03230 seconds
Time After: 0.03964 seconds
Time Taken: 0.00735 seconds
Time Before: 0.05370 seconds
Time After: 0.05416 seconds
Time Before: 0.05644 seconds
Time After: 0.05766 seconds
Time Before: 0.05304 seconds
Time After: 0.05787 seconds
Time Taken: 0.00483 seconds
Time Before: 0.09720 seconds
Time After: 0.09735 seconds
Time Before: 0.11332 seconds
Time After: 0.11456 seconds
Time Before: 0.12339 seconds
Time After: 0.12356 seconds
Time Before: 0.12604 seconds
Time After: 0.12745 seconds
UPDATE session SET lastactivity = 1776668080, location = '/forums/private.php?do=newpm&explain=1&u=101763' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.14833 seconds
Time After: 0.14859 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
