Time Before: 0.01124 seconds
Time After: 0.01474 seconds
Time Taken: 0.00350 seconds
Time Before: 0.01483 seconds
Time After: 0.01523 seconds
Time Before: 0.01546 seconds
Time After: 0.01558 seconds
Time Before: 0.01640 seconds
Time After: 0.01902 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01565 seconds
Time After: 0.02318 seconds
Time Taken: 0.00753 seconds
Time Before: 0.02790 seconds
Time After: 0.02839 seconds
Time Before: 0.03146 seconds
Time After: 0.03264 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02721 seconds
Time After: 0.03285 seconds
Time Taken: 0.00564 seconds
Memory After: 2,261.820 KB
Time Before: 0.05522 seconds
Time After: 0.05536 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06446 seconds
Time After: 0.06569 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.067593812942505
Time Before: 0.07173 seconds
Time After: 0.07191 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07459 seconds
Time After: 0.07602 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788871098, location = '/forums/private.php?do=newpm&explain=1&u=101767', badlocation = 1
Time Before: 0.09303 seconds
Time After: 0.09362 seconds
Time Taken: 0.00059 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.092020988464355 seconds with 9 queries, spending 0.0083827972412109 doing MySQL queries and 0.083638191223145 doing PHP things.
