Time Before: 0.00801 seconds
Time After: 0.01111 seconds
Time Taken: 0.00310 seconds
Time Before: 0.01120 seconds
Time After: 0.01160 seconds
Time Before: 0.01183 seconds
Time After: 0.01195 seconds
Time Before: 0.01278 seconds
Time After: 0.01540 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01202 seconds
Time After: 0.01943 seconds
Time Taken: 0.00742 seconds
Time Before: 0.02246 seconds
Time After: 0.02290 seconds
Time Before: 0.02601 seconds
Time After: 0.02719 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02173 seconds
Time After: 0.02738 seconds
Time Taken: 0.00565 seconds
Time Before: 0.04025 seconds
Time After: 0.04040 seconds
Time Before: 0.04689 seconds
Time After: 0.04817 seconds
Time Before: 0.05466 seconds
Time After: 0.05480 seconds
Time Before: 0.05696 seconds
Time After: 0.05845 seconds
UPDATE session SET lastactivity = 1783075343, location = '/forums/private.php?do=newpm&explain=1&u=101783' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.07559 seconds
Time After: 0.07594 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
