Time Before: 0.00812 seconds
Time After: 0.01112 seconds
Time Taken: 0.00300 seconds
Time Before: 0.01119 seconds
Time After: 0.01158 seconds
Time Before: 0.01182 seconds
Time After: 0.01193 seconds
Time Before: 0.01269 seconds
Time After: 0.01525 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01198 seconds
Time After: 0.01913 seconds
Time Taken: 0.00715 seconds
Time Before: 0.02344 seconds
Time After: 0.02389 seconds
Time Before: 0.02660 seconds
Time After: 0.02782 seconds
Time Before: 0.02269 seconds
Time After: 0.02807 seconds
Time Taken: 0.00538 seconds
Time Before: 0.04293 seconds
Time After: 0.04309 seconds
Time Before: 0.05021 seconds
Time After: 0.05145 seconds
Time Before: 0.05943 seconds
Time After: 0.05963 seconds
Time Before: 0.06186 seconds
Time After: 0.06336 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1776986638, location = '/forums/private.php?do=newpm&explain=1&u=101791' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.08070 seconds
Time After: 0.08108 seconds
