Time Before: 0.00199 seconds
Time After: 0.00278 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00285 seconds
Time After: 0.00325 seconds
Time Before: 0.00347 seconds
Time After: 0.00362 seconds
Time Before: 0.00429 seconds
Time After: 0.00664 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00367 seconds
Time After: 0.01023 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01225 seconds
Time After: 0.01259 seconds
Time Before: 0.01477 seconds
Time After: 0.01597 seconds
Time Before: 0.01168 seconds
Time After: 0.01613 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02135 seconds
Time After: 0.02157 seconds
Time Before: 0.02353 seconds
Time After: 0.02476 seconds
End call of global.php: 0.026484966278076
Time Before: 0.02763 seconds
Time After: 0.02778 seconds
Time Before: 0.02984 seconds
Time After: 0.03125 seconds
SET lastactivity = 1776553304, location = '/forums/private.php?do=newpm&explain=1&u=101798', badlocation = 1
Time Before: 0.04461 seconds
Time After: 0.04491 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.04365086555481 seconds with 9 queries, spending 0.0077691078186035 doing MySQL queries and 0.035881757736206 doing PHP things.
