Time Before: 0.00140 seconds
Time After: 0.00198 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00206 seconds
Time After: 0.00261 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00284 seconds
Time After: 0.00303 seconds
Time Before: 0.00379 seconds
Time After: 0.00654 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00311 seconds
Time After: 0.00993 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01179 seconds
Time After: 0.01218 seconds
Time Before: 0.01494 seconds
Time After: 0.01611 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01116 seconds
Time After: 0.01629 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02129 seconds
Time After: 0.02145 seconds
Time Before: 0.02343 seconds
Time After: 0.02463 seconds
End call of global.php: 0.026306867599487
Time Before: 0.02759 seconds
Time After: 0.02773 seconds
Time Before: 0.02978 seconds
Time After: 0.03134 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101810', badlocation = 1
Time Before: 0.04376 seconds
Time After: 0.04409 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.042855024337769 seconds with 9 queries, spending 0.0084455013275146 doing MySQL queries and 0.034409523010254 doing PHP things.
