Time Before: 0.00625 seconds
Time After: 0.01057 seconds
Time Taken: 0.00431 seconds
Time Before: 0.01067 seconds
Time After: 0.01117 seconds
Time Before: 0.01143 seconds
Time After: 0.01157 seconds
Time Before: 0.01228 seconds
Time After: 0.01501 seconds
Time Taken: 0.00273 seconds
Time Before: 0.01163 seconds
Time After: 0.01944 seconds
Time Taken: 0.00781 seconds
Time Before: 0.02428 seconds
Time After: 0.02474 seconds
Time Before: 0.02765 seconds
Time After: 0.02999 seconds
Time Taken: 0.00234 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02359 seconds
Time After: 0.03023 seconds
Time Taken: 0.00665 seconds
Memory After: 2,261.703 KB
Time Before: 0.04315 seconds
Time After: 0.04348 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05249 seconds
Time After: 0.05383 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.056045055389404
Time Before: 0.06031 seconds
Time After: 0.06046 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06300 seconds
Time After: 0.06446 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=101819'
Time Before: 0.08282 seconds
Time After: 0.08307 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.081688165664673 seconds with 9 queries, spending 0.0097217559814453 doing MySQL queries and 0.071966409683228 doing PHP things.
