Time Before: 0.01986 seconds
Time After: 0.02655 seconds
Time Taken: 0.00669 seconds
Time Before: 0.02665 seconds
Time After: 0.02712 seconds
Time Before: 0.02734 seconds
Time After: 0.02746 seconds
Time Before: 0.02816 seconds
Time After: 0.03049 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02752 seconds
Time After: 0.03596 seconds
Time Taken: 0.00844 seconds
Time Before: 0.04351 seconds
Time After: 0.04394 seconds
Time Before: 0.04657 seconds
Time After: 0.04777 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04269 seconds
Time After: 0.04797 seconds
Time Taken: 0.00528 seconds
Memory After: 2,261.820 KB
Time Before: 0.08349 seconds
Time After: 0.08365 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10143 seconds
Time After: 0.10269 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11413 seconds
Time After: 0.11429 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11714 seconds
Time After: 0.11862 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788883652, location = '/forums/private.php?do=newpm&explain=1&u=101837' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.13684 seconds
Time After: 0.13711 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
