Time Before: 0.02456 seconds
Time After: 0.02974 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02985 seconds
Time After: 0.03019 seconds
Time Before: 0.03050 seconds
Time After: 0.03060 seconds
Time Taken: 0.00010 seconds
Time Before: 0.03132 seconds
Time After: 0.03375 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03065 seconds
Time After: 0.03782 seconds
Time Taken: 0.00716 seconds
Time Before: 0.04694 seconds
Time After: 0.04724 seconds
Time Before: 0.04955 seconds
Time After: 0.05074 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04620 seconds
Time After: 0.05098 seconds
Time Taken: 0.00479 seconds
Memory After: 2,261.703 KB
Time Before: 0.09207 seconds
Time After: 0.09221 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10993 seconds
Time After: 0.11158 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12060 seconds
Time After: 0.12076 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12375 seconds
Time After: 0.12541 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101861' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14451 seconds
Time After: 0.14472 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
