Time Before: 0.00135 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00222 seconds
Time Before: 0.00247 seconds
Time After: 0.00266 seconds
Time Before: 0.00328 seconds
Time After: 0.00544 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00270 seconds
Time After: 0.00887 seconds
Time Taken: 0.00617 seconds
Time Before: 0.01118 seconds
Time After: 0.01164 seconds
Time Before: 0.01410 seconds
Time After: 0.01525 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01057 seconds
Time After: 0.01544 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02054 seconds
Time After: 0.02079 seconds
Time Before: 0.02278 seconds
Time After: 0.02404 seconds
Time Before: 0.02690 seconds
Time After: 0.02706 seconds
Time Before: 0.02905 seconds
Time After: 0.03055 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788870329, location = '/forums/private.php?do=newpm&explain=1&u=101862' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04534 seconds
Time After: 0.04559 seconds
