Time Before: 0.01341 seconds
Time After: 0.01683 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01692 seconds
Time After: 0.01760 seconds
Time Taken: 0.00068 seconds
Time Before: 0.01788 seconds
Time After: 0.01825 seconds
Time Before: 0.01920 seconds
Time After: 0.02217 seconds
Time Taken: 0.00298 seconds
Time Before: 0.01833 seconds
Time After: 0.02586 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03276 seconds
Time After: 0.03312 seconds
Time Before: 0.03462 seconds
Time After: 0.03591 seconds
Time Before: 0.03202 seconds
Time After: 0.03618 seconds
Time Taken: 0.00416 seconds
Time Before: 0.07524 seconds
Time After: 0.07541 seconds
Time Before: 0.08751 seconds
Time After: 0.08879 seconds
Time Before: 0.09579 seconds
Time After: 0.09601 seconds
Time Before: 0.09858 seconds
Time After: 0.10008 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101882', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11873 seconds
Time After: 0.11904 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
