Time Before: 0.02481 seconds
Time After: 0.03378 seconds
Time Taken: 0.00897 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.03393 seconds
Time After: 0.03436 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.03463 seconds
Time After: 0.03477 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.03557 seconds
Time After: 0.03830 seconds
Time Taken: 0.00273 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.03483 seconds
Time After: 0.04299 seconds
Time Taken: 0.00816 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.05558 seconds
Time After: 0.05602 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.05958 seconds
Time After: 0.06174 seconds
Time Taken: 0.00217 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.05478 seconds
Time After: 0.06201 seconds
Time Taken: 0.00723 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.10189 seconds
Time After: 0.10201 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.12175 seconds
Time After: 0.12304 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
Time Before: 0.13409 seconds
Time After: 0.13422 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.13671 seconds
Time After: 0.13815 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
UPDATE session SET lastactivity = 1789120845, location = '/forums/private.php?do=newpm&explain=1&u=101923', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.15664 seconds
Time After: 0.15693 seconds
Memory Before: 4,295.664 KB
Memory After: 4,295.875 KB
