Time Before: 0.02554 seconds
Time After: 0.03066 seconds
Time Taken: 0.00512 seconds
Time Before: 0.03076 seconds
Time After: 0.03119 seconds
Time Before: 0.03141 seconds
Time After: 0.03154 seconds
Time Before: 0.03238 seconds
Time After: 0.03649 seconds
Time Taken: 0.00411 seconds
Time Before: 0.03161 seconds
Time After: 0.04157 seconds
Time Taken: 0.00996 seconds
Time Before: 0.05220 seconds
Time After: 0.05260 seconds
Time Before: 0.05534 seconds
Time After: 0.05691 seconds
Time Taken: 0.00156 seconds
Time Before: 0.05154 seconds
Time After: 0.05716 seconds
Time Taken: 0.00563 seconds
Time Before: 0.10085 seconds
Time After: 0.10125 seconds
Time Before: 0.12233 seconds
Time After: 0.12363 seconds
Time Before: 0.13659 seconds
Time After: 0.13679 seconds
Time Before: 0.14004 seconds
Time After: 0.14328 seconds
Time Taken: 0.00324 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101925' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.16095 seconds
Time After: 0.16436 seconds
Time Taken: 0.00341 seconds
