Time Before: 0.02271 seconds
Time After: 0.02826 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02834 seconds
Time After: 0.02875 seconds
Time Before: 0.02900 seconds
Time After: 0.02912 seconds
Time Before: 0.02998 seconds
Time After: 0.03218 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02917 seconds
Time After: 0.03657 seconds
Time Taken: 0.00740 seconds
Time Before: 0.04235 seconds
Time After: 0.04276 seconds
Time Before: 0.04568 seconds
Time After: 0.04688 seconds
Time Before: 0.04161 seconds
Time After: 0.04710 seconds
Time Taken: 0.00549 seconds
Time Before: 0.08120 seconds
Time After: 0.08137 seconds
Time Before: 0.09341 seconds
Time After: 0.09466 seconds
Time Before: 0.10338 seconds
Time After: 0.10361 seconds
Time Before: 0.10641 seconds
Time After: 0.10790 seconds
UPDATE session SET lastactivity = 1776613721, location = '/forums/private.php?do=newpm&explain=1&u=101926' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.12503 seconds
Time After: 0.12537 seconds
