Time Before: 0.01246 seconds
Time After: 0.01638 seconds
Time Taken: 0.00393 seconds
Time Before: 0.01645 seconds
Time After: 0.01741 seconds
Time Taken: 0.00096 seconds
Time Before: 0.01784 seconds
Time After: 0.01803 seconds
Time Before: 0.01890 seconds
Time After: 0.02124 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01810 seconds
Time After: 0.02553 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03451 seconds
Time After: 0.03470 seconds
Time Before: 0.03638 seconds
Time After: 0.03761 seconds
Time Before: 0.03374 seconds
Time After: 0.03788 seconds
Time Taken: 0.00415 seconds
Time Before: 0.06352 seconds
Time After: 0.06369 seconds
Time Before: 0.07860 seconds
Time After: 0.07987 seconds
Time Before: 0.08865 seconds
Time After: 0.08883 seconds
Time Before: 0.09158 seconds
Time After: 0.09314 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=101929', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.11078 seconds
Time After: 0.11106 seconds
