Time Before: 0.00859 seconds
Time After: 0.01230 seconds
Time Taken: 0.00371 seconds
Time Before: 0.01241 seconds
Time After: 0.01281 seconds
Time Before: 0.01311 seconds
Time After: 0.01326 seconds
Time Before: 0.01408 seconds
Time After: 0.01696 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01334 seconds
Time After: 0.02103 seconds
Time Taken: 0.00769 seconds
Time Before: 0.02630 seconds
Time After: 0.02667 seconds
Time Before: 0.02951 seconds
Time After: 0.03070 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02546 seconds
Time After: 0.03088 seconds
Time Taken: 0.00541 seconds
Time Before: 0.04794 seconds
Time After: 0.04809 seconds
Time Before: 0.05639 seconds
Time After: 0.05773 seconds
Time Taken: 0.00134 seconds
Time Before: 0.06435 seconds
Time After: 0.06450 seconds
Time Before: 0.06685 seconds
Time After: 0.06827 seconds
UPDATE session SET lastactivity = 1776500218, location = '/forums/private.php?do=newpm&explain=1&u=101931' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.08280 seconds
Time After: 0.08322 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
