Time Before: 0.00788 seconds
Time After: 0.01233 seconds
Time Taken: 0.00445 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.01244 seconds
Time After: 0.01282 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.01308 seconds
Time After: 0.01318 seconds
Time Taken: 0.00010 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.01381 seconds
Time After: 0.01614 seconds
Time Taken: 0.00233 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.01325 seconds
Time After: 0.02062 seconds
Time Taken: 0.00737 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.02613 seconds
Time After: 0.02642 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.02850 seconds
Time After: 0.02971 seconds
Memory Before: 2,148.281 KB
Memory After: 2,148.141 KB
Time Before: 0.02552 seconds
Time After: 0.02996 seconds
Time Taken: 0.00444 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.164 KB
Time Before: 0.04113 seconds
Time After: 0.04125 seconds
Memory Before: 2,814.719 KB
Memory After: 2,815.234 KB
Time Before: 0.05891 seconds
Time After: 0.06019 seconds
Memory Before: 2,903.047 KB
Memory After: 2,903.641 KB
End call of global.php: 0.062366008758545
Time Before: 0.06505 seconds
Time After: 0.06520 seconds
Memory Before: 3,539.773 KB
Memory After: 3,540.203 KB
Time Before: 0.06745 seconds
Time After: 0.06896 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=101950'
Time Before: 0.08466 seconds
Time After: 0.08516 seconds
Memory Before: 4,294.930 KB
Memory After: 4,295.172 KB
Page generated in 0.083584070205688 seconds with 9 queries, spending 0.0078833103179932 doing MySQL queries and 0.075700759887695 doing PHP things.
