Time Before: 0.00130 seconds
Time After: 0.00174 seconds
Time Before: 0.00181 seconds
Time After: 0.00240 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00265 seconds
Time After: 0.00278 seconds
Time Before: 0.00352 seconds
Time After: 0.00659 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00283 seconds
Time After: 0.00998 seconds
Time Taken: 0.00715 seconds
Time Before: 0.01177 seconds
Time After: 0.01215 seconds
Time Before: 0.01519 seconds
Time After: 0.01641 seconds
Time Before: 0.01111 seconds
Time After: 0.01660 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02170 seconds
Time After: 0.02189 seconds
Time Before: 0.02413 seconds
Time After: 0.02539 seconds
End call of global.php: 0.027000904083252
Time Before: 0.02826 seconds
Time After: 0.02841 seconds
Time Before: 0.03039 seconds
Time After: 0.03184 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101967'
Time Before: 0.04421 seconds
Time After: 0.04457 seconds
Page generated in 0.043322086334229 seconds with 9 queries, spending 0.0087995529174805 doing MySQL queries and 0.034522533416748 doing PHP things.
