Time Before: 0.01546 seconds
Time After: 0.02133 seconds
Time Taken: 0.00586 seconds
Time Before: 0.02144 seconds
Time After: 0.02200 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02233 seconds
Time After: 0.02251 seconds
Time Before: 0.02354 seconds
Time After: 0.02580 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02260 seconds
Time After: 0.03152 seconds
Time Taken: 0.00892 seconds
Time Before: 0.04163 seconds
Time After: 0.04204 seconds
Time Before: 0.04451 seconds
Time After: 0.04571 seconds
Time Before: 0.04080 seconds
Time After: 0.04589 seconds
Time Taken: 0.00509 seconds
Time Before: 0.07383 seconds
Time After: 0.07402 seconds
Time Before: 0.08904 seconds
Time After: 0.09032 seconds
End call of global.php: 0.092427968978882
Time Before: 0.10122 seconds
Time After: 0.10140 seconds
Time Before: 0.10454 seconds
Time After: 0.10602 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=101971'
Time Before: 0.12667 seconds
Time After: 0.12708 seconds
Page generated in 0.12558007240295 seconds with 9 queries, spending 0.0081584453582764 doing MySQL queries and 0.11742162704468 doing PHP things.
