Time Before: 0.02320 seconds
Time After: 0.03056 seconds
Time Taken: 0.00736 seconds
Time Before: 0.03066 seconds
Time After: 0.03199 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03240 seconds
Time After: 0.03262 seconds
Time Before: 0.03339 seconds
Time After: 0.03806 seconds
Time Taken: 0.00467 seconds
Time Before: 0.03269 seconds
Time After: 0.04256 seconds
Time Taken: 0.00987 seconds
Time Before: 0.05056 seconds
Time After: 0.05099 seconds
Time Before: 0.05339 seconds
Time After: 0.05458 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04991 seconds
Time After: 0.05482 seconds
Time Taken: 0.00491 seconds
Memory After: 2,261.703 KB
Time Before: 0.08199 seconds
Time After: 0.08216 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10080 seconds
Time After: 0.10211 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11309 seconds
Time After: 0.11345 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11602 seconds
Time After: 0.11747 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102018', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13621 seconds
Time After: 0.13648 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
