Time Before: 0.03562 seconds
Time After: 0.04546 seconds
Time Taken: 0.00984 seconds
Time Before: 0.04558 seconds
Time After: 0.04613 seconds
Time Taken: 0.00055 seconds
Time Before: 0.04650 seconds
Time After: 0.04667 seconds
Time Before: 0.04759 seconds
Time After: 0.05080 seconds
Time Taken: 0.00320 seconds
Time Before: 0.04674 seconds
Time After: 0.05637 seconds
Time Taken: 0.00962 seconds
Time Before: 0.06643 seconds
Time After: 0.06734 seconds
Time Taken: 0.00090 seconds
Time Before: 0.07044 seconds
Time After: 0.07184 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06524 seconds
Time After: 0.07211 seconds
Time Taken: 0.00687 seconds
Memory After: 2,261.820 KB
Time Before: 0.13002 seconds
Time After: 0.13022 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.15197 seconds
Time After: 0.15349 seconds
Time Taken: 0.00152 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.16600 seconds
Time After: 0.16667 seconds
Time Taken: 0.00068 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.16981 seconds
Time After: 0.17187 seconds
Time Taken: 0.00206 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788887227, location = '/forums/private.php?do=newpm&explain=1&u=102026', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.19289 seconds
Time After: 0.19322 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
