Time Before: 0.00157 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00248 seconds
Time Before: 0.00267 seconds
Time After: 0.00278 seconds
Time Before: 0.00347 seconds
Time After: 0.00556 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00282 seconds
Time After: 0.00890 seconds
Time Taken: 0.00607 seconds
Time Before: 0.01090 seconds
Time After: 0.01133 seconds
Time Before: 0.01403 seconds
Time After: 0.01542 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01034 seconds
Time After: 0.01568 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02307 seconds
Time After: 0.02325 seconds
Time Before: 0.02521 seconds
Time After: 0.02644 seconds
End call of global.php: 0.028080940246582
Time Before: 0.02954 seconds
Time After: 0.02971 seconds
Time Before: 0.03226 seconds
Time After: 0.03372 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102051', badlocation = 1
Time Before: 0.04905 seconds
Time After: 0.04934 seconds
Page generated in 0.048127889633179 seconds with 9 queries, spending 0.0077056884765625 doing MySQL queries and 0.040422201156616 doing PHP things.
