Time Before: 0.01916 seconds
Time After: 0.02705 seconds
Time Taken: 0.00789 seconds
Time Before: 0.02719 seconds
Time After: 0.02768 seconds
Time Before: 0.02800 seconds
Time After: 0.02813 seconds
Time Before: 0.02945 seconds
Time After: 0.03173 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02820 seconds
Time After: 0.03623 seconds
Time Taken: 0.00804 seconds
Time Before: 0.04555 seconds
Time After: 0.04586 seconds
Time Before: 0.04752 seconds
Time After: 0.04874 seconds
Time Before: 0.04479 seconds
Time After: 0.04901 seconds
Time Taken: 0.00422 seconds
Time Before: 0.09050 seconds
Time After: 0.09063 seconds
Time Before: 0.40765 seconds
Time After: 0.40895 seconds
Time Before: 0.42210 seconds
Time After: 0.42231 seconds
Time Before: 0.42487 seconds
Time After: 0.42629 seconds
UPDATE session SET lastactivity = 1782996556, location = '/forums/private.php?do=newpm&explain=1&u=102057', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.44316 seconds
Time After: 0.44357 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
