Time Before: 0.01241 seconds
Time After: 0.01511 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01522 seconds
Time After: 0.01618 seconds
Time Taken: 0.00096 seconds
Time Before: 0.01658 seconds
Time After: 0.01676 seconds
Time Before: 0.01768 seconds
Time After: 0.02052 seconds
Time Taken: 0.00284 seconds
Time Before: 0.01683 seconds
Time After: 0.02472 seconds
Time Taken: 0.00789 seconds
Time Before: 0.03074 seconds
Time After: 0.03114 seconds
Time Before: 0.03374 seconds
Time After: 0.03495 seconds
Time Before: 0.02998 seconds
Time After: 0.03518 seconds
Time Taken: 0.00520 seconds
Time Before: 0.05355 seconds
Time After: 0.05375 seconds
Time Before: 0.06508 seconds
Time After: 0.06633 seconds
Time Before: 0.07562 seconds
Time After: 0.07580 seconds
Time Before: 0.07875 seconds
Time After: 0.08029 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1785386401, location = '/forums/private.php?do=newpm&explain=1&u=102075', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.10055 seconds
Time After: 0.10084 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
