Time Before: 0.02812 seconds
Time After: 0.03312 seconds
Time Taken: 0.00500 seconds
Time Before: 0.03322 seconds
Time After: 0.03368 seconds
Time Before: 0.03390 seconds
Time After: 0.03403 seconds
Time Before: 0.03472 seconds
Time After: 0.03714 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03409 seconds
Time After: 0.04127 seconds
Time Taken: 0.00717 seconds
Time Before: 0.05405 seconds
Time After: 0.05450 seconds
Time Before: 0.05740 seconds
Time After: 0.05863 seconds
Time Before: 0.05326 seconds
Time After: 0.05888 seconds
Time Taken: 0.00563 seconds
Time Before: 0.10649 seconds
Time After: 0.10664 seconds
Time Before: 0.12365 seconds
Time After: 0.12489 seconds
End call of global.php: 0.12705898284912
Time Before: 0.13809 seconds
Time After: 0.13840 seconds
Time Before: 0.14139 seconds
Time After: 0.14289 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1784821730, location = '/forums/private.php?do=newpm&explain=1&u=102102', badlocation = 1
Time Before: 0.16370 seconds
Time After: 0.16404 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.16232895851135 seconds with 9 queries, spending 0.0082335472106934 doing MySQL queries and 0.15409541130066 doing PHP things.
