Time Before: 0.02196 seconds
Time After: 0.03081 seconds
Time Taken: 0.00885 seconds
Time Before: 0.03090 seconds
Time After: 0.03140 seconds
Time Before: 0.03172 seconds
Time After: 0.03185 seconds
Time Before: 0.03273 seconds
Time After: 0.03462 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03193 seconds
Time After: 0.03978 seconds
Time Taken: 0.00785 seconds
Time Before: 0.05012 seconds
Time After: 0.05059 seconds
Time Before: 0.05305 seconds
Time After: 0.05515 seconds
Time Taken: 0.00210 seconds
Time Before: 0.04932 seconds
Time After: 0.05542 seconds
Time Taken: 0.00610 seconds
Time Before: 0.10005 seconds
Time After: 0.10024 seconds
Time Before: 0.12239 seconds
Time After: 0.12364 seconds
End call of global.php: 0.12595009803772
Time Before: 0.13295 seconds
Time After: 0.13315 seconds
Time Before: 0.13574 seconds
Time After: 0.13723 seconds
SET lastactivity = 1777137183, location = '/forums/private.php?do=newpm&explain=1&u=102103'
WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.15676 seconds
Time After: 0.15704 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.1556191444397 seconds with 9 queries, spending 0.008502721786499 doing MySQL queries and 0.1471164226532 doing PHP things.
