Time Before: 0.00153 seconds
Time After: 0.00200 seconds
Time Before: 0.00207 seconds
Time After: 0.00250 seconds
Time Before: 0.00270 seconds
Time After: 0.00285 seconds
Time Before: 0.00366 seconds
Time After: 0.00583 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00291 seconds
Time After: 0.00940 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01179 seconds
Time After: 0.01269 seconds
Time Taken: 0.00090 seconds
Time Before: 0.01541 seconds
Time After: 0.01667 seconds
Time Before: 0.01078 seconds
Time After: 0.01693 seconds
Time Taken: 0.00615 seconds
Time Before: 0.02290 seconds
Time After: 0.02311 seconds
Time Before: 0.02536 seconds
Time After: 0.02671 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03109 seconds
Time After: 0.03123 seconds
Time Before: 0.03352 seconds
Time After: 0.03493 seconds
UPDATE session SET lastactivity = 1788887321, location = '/forums/private.php?do=newpm&explain=1&u=102105', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04785 seconds
Time After: 0.04838 seconds
