Time Before: 0.00822 seconds
Time After: 0.01164 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01175 seconds
Time After: 0.01217 seconds
Time Before: 0.01241 seconds
Time After: 0.01254 seconds
Time Before: 0.01349 seconds
Time After: 0.01602 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01262 seconds
Time After: 0.02048 seconds
Time Taken: 0.00786 seconds
Time Before: 0.02495 seconds
Time After: 0.02538 seconds
Time Before: 0.02706 seconds
Time After: 0.02870 seconds
Time Taken: 0.00164 seconds
Time Before: 0.02410 seconds
Time After: 0.02893 seconds
Time Taken: 0.00483 seconds
Time Before: 0.04437 seconds
Time After: 0.04450 seconds
Time Before: 0.05206 seconds
Time After: 0.05337 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.055972099304199
Time Before: 0.06014 seconds
Time After: 0.06031 seconds
Time Before: 0.06428 seconds
Time After: 0.06572 seconds
SET lastactivity = 1785289891, location = '/forums/private.php?do=newpm&explain=1&u=102111'
Time Before: 0.08468 seconds
Time After: 0.08504 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.083513021469116 seconds with 9 queries, spending 0.0085659027099609 doing MySQL queries and 0.074947118759155 doing PHP things.
