Time Before: 0.00400 seconds
Time After: 0.00475 seconds
Time Taken: 0.00075 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00487 seconds
Time After: 0.00528 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00554 seconds
Time After: 0.00567 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00658 seconds
Time After: 0.00903 seconds
Time Taken: 0.00245 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00575 seconds
Time After: 0.01426 seconds
Time Taken: 0.00851 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01691 seconds
Time After: 0.01713 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01877 seconds
Time After: 0.02005 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01612 seconds
Time After: 0.02030 seconds
Time Taken: 0.00418 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02810 seconds
Time After: 0.02826 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03833 seconds
Time After: 0.03960 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04813 seconds
Time After: 0.04831 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.05158 seconds
Time After: 0.05304 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1769369921, location = '/forums/private.php?do=newpm&explain=1&u=102128', badlocation = 1 WHERE sessionhash = 'e60efe98bb3a97c417ccaae1b39ae601'
Time Before: 0.07204 seconds
Time After: 0.07265 seconds
Time Taken: 0.00061 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
