Time Before: 0.00964 seconds
Time After: 0.01404 seconds
Time Taken: 0.00441 seconds
Time Before: 0.01416 seconds
Time After: 0.01458 seconds
Time Before: 0.01539 seconds
Time After: 0.01553 seconds
Time Before: 0.01666 seconds
Time After: 0.01902 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01561 seconds
Time After: 0.02477 seconds
Time Taken: 0.00916 seconds
Time Before: 0.02825 seconds
Time After: 0.02863 seconds
Time Before: 0.03119 seconds
Time After: 0.03377 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02764 seconds
Time After: 0.03398 seconds
Time Taken: 0.00635 seconds
Time Before: 0.05166 seconds
Time After: 0.05180 seconds
Time Before: 0.06220 seconds
Time After: 0.06353 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.066151142120361
Time Before: 0.07109 seconds
Time After: 0.07128 seconds
Time Before: 0.07422 seconds
Time After: 0.07566 seconds
SET lastactivity = 1788920325, location = '/forums/private.php?do=newpm&explain=1&u=102138'
Time Before: 0.09487 seconds
Time After: 0.09516 seconds
Page generated in 0.093693971633911 seconds with 9 queries, spending 0.0092527866363525 doing MySQL queries and 0.084441184997559 doing PHP things.
