Time Before: 0.00149 seconds
Time After: 0.00195 seconds
Time Before: 0.00201 seconds
Time After: 0.00248 seconds
Time Before: 0.00273 seconds
Time After: 0.00295 seconds
Time Before: 0.00363 seconds
Time After: 0.00589 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00300 seconds
Time After: 0.00928 seconds
Time Taken: 0.00628 seconds
Time Before: 0.01110 seconds
Time After: 0.01154 seconds
Time Before: 0.01293 seconds
Time After: 0.01420 seconds
Time Before: 0.01045 seconds
Time After: 0.01437 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02207 seconds
Time After: 0.02224 seconds
Time Before: 0.02464 seconds
Time After: 0.02593 seconds
Time Before: 0.02896 seconds
Time After: 0.02915 seconds
Time Before: 0.03116 seconds
Time After: 0.03257 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102189', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04531 seconds
Time After: 0.04558 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
