Time Before: 0.01014 seconds
Time After: 0.01433 seconds
Time Taken: 0.00419 seconds
Time Before: 0.01440 seconds
Time After: 0.01489 seconds
Time Before: 0.01510 seconds
Time After: 0.01527 seconds
Time Before: 0.01616 seconds
Time After: 0.01869 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01535 seconds
Time After: 0.02367 seconds
Time Taken: 0.00832 seconds
Time Before: 0.02943 seconds
Time After: 0.02985 seconds
Time Before: 0.03247 seconds
Time After: 0.03366 seconds
Time Before: 0.02878 seconds
Time After: 0.03390 seconds
Time Taken: 0.00512 seconds
Time Before: 0.05294 seconds
Time After: 0.05310 seconds
Time Before: 0.06146 seconds
Time After: 0.06272 seconds
End call of global.php: 0.064888954162598
Time Before: 0.06986 seconds
Time After: 0.07004 seconds
Time Before: 0.07241 seconds
Time After: 0.07385 seconds
SET lastactivity = 1788933070, location = '/forums/private.php?do=newpm&explain=1&u=102193'
Time Before: 0.09151 seconds
Time After: 0.09181 seconds
Page generated in 0.090379953384399 seconds with 9 queries, spending 0.0081355571746826 doing MySQL queries and 0.082244396209717 doing PHP things.
