Time Before: 0.01302 seconds
Time After: 0.01839 seconds
Time Taken: 0.00537 seconds
Time Before: 0.01849 seconds
Time After: 0.01892 seconds
Time Before: 0.01916 seconds
Time After: 0.01933 seconds
Time Before: 0.02021 seconds
Time After: 0.02255 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01939 seconds
Time After: 0.02687 seconds
Time Taken: 0.00748 seconds
Time Before: 0.03460 seconds
Time After: 0.03483 seconds
Time Before: 0.03750 seconds
Time After: 0.03874 seconds
Time Before: 0.03389 seconds
Time After: 0.03898 seconds
Time Taken: 0.00509 seconds
Time Before: 0.06622 seconds
Time After: 0.06638 seconds
Time Before: 0.14357 seconds
Time After: 0.14483 seconds
Time Before: 0.15497 seconds
Time After: 0.15517 seconds
Time Before: 0.15784 seconds
Time After: 0.15928 seconds
UPDATE session SET lastactivity = 1776686122, location = '/forums/private.php?do=newpm&explain=1&u=102195', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.17669 seconds
Time After: 0.17702 seconds
