Time Before: 0.00154 seconds
Time After: 0.00201 seconds
Time Before: 0.00208 seconds
Time After: 0.00258 seconds
Time Before: 0.00285 seconds
Time After: 0.00298 seconds
Time Before: 0.00385 seconds
Time After: 0.00749 seconds
Time Taken: 0.00364 seconds
Time Before: 0.00305 seconds
Time After: 0.01240 seconds
Time Taken: 0.00935 seconds
Time Before: 0.01438 seconds
Time After: 0.01475 seconds
Time Before: 0.01714 seconds
Time After: 0.01835 seconds
Time Before: 0.01374 seconds
Time After: 0.01861 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02421 seconds
Time After: 0.02436 seconds
Time Before: 0.02623 seconds
Time After: 0.02747 seconds
Time Before: 0.03016 seconds
Time After: 0.03032 seconds
Time Before: 0.03239 seconds
Time After: 0.03397 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102196' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04646 seconds
Time After: 0.04684 seconds
