Time Before: 0.00788 seconds
Time After: 0.01070 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01078 seconds
Time After: 0.01122 seconds
Time Before: 0.01154 seconds
Time After: 0.01171 seconds
Time Before: 0.01246 seconds
Time After: 0.01539 seconds
Time Taken: 0.00294 seconds
Time Before: 0.01178 seconds
Time After: 0.01936 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02402 seconds
Time After: 0.02442 seconds
Time Before: 0.02582 seconds
Time After: 0.02706 seconds
Time Before: 0.02345 seconds
Time After: 0.02723 seconds
Time Taken: 0.00378 seconds
Time Before: 0.04141 seconds
Time After: 0.04156 seconds
Time Before: 0.05189 seconds
Time After: 0.05351 seconds
Time Taken: 0.00162 seconds
End call of global.php: 0.055536031723022
Time Before: 0.05929 seconds
Time After: 0.05954 seconds
Time Before: 0.06155 seconds
Time After: 0.06314 seconds
Time Taken: 0.00159 seconds
SET lastactivity = 1784808468, location = '/forums/private.php?do=newpm&explain=1&u=102204'
Time Before: 0.07705 seconds
Time After: 0.07737 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.076093912124634 seconds with 9 queries, spending 0.0091300010681152 doing MySQL queries and 0.066963911056519 doing PHP things.
