Time Before: 0.00157 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00253 seconds
Time Before: 0.00271 seconds
Time After: 0.00286 seconds
Time Before: 0.00372 seconds
Time After: 0.00634 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00291 seconds
Time After: 0.01070 seconds
Time Taken: 0.00779 seconds
Time Before: 0.01258 seconds
Time After: 0.01330 seconds
Time Taken: 0.00072 seconds
Time Before: 0.01649 seconds
Time After: 0.01779 seconds
Time Before: 0.01196 seconds
Time After: 0.01806 seconds
Time Taken: 0.00610 seconds
Time Before: 0.02482 seconds
Time After: 0.02507 seconds
Time Before: 0.02737 seconds
Time After: 0.02863 seconds
End call of global.php: 0.030544996261597
Time Before: 0.03223 seconds
Time After: 0.03248 seconds
Time Before: 0.03544 seconds
Time After: 0.03691 seconds
SET lastactivity = 1782886613, location = '/forums/private.php?do=newpm&explain=1&u=102217'
Time Before: 0.05197 seconds
Time After: 0.05225 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.050720930099487 seconds with 9 queries, spending 0.0086658000946045 doing MySQL queries and 0.042055130004883 doing PHP things.
