Time Before: 0.02475 seconds
Time After: 0.02942 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02949 seconds
Time After: 0.02998 seconds
Time Before: 0.03024 seconds
Time After: 0.03037 seconds
Time Before: 0.03127 seconds
Time After: 0.03380 seconds
Time Taken: 0.00253 seconds
Time Before: 0.03043 seconds
Time After: 0.03800 seconds
Time Taken: 0.00757 seconds
Time Before: 0.04864 seconds
Time After: 0.04896 seconds
Time Before: 0.05084 seconds
Time After: 0.05209 seconds
Time Before: 0.04796 seconds
Time After: 0.05230 seconds
Time Taken: 0.00434 seconds
Time Before: 0.09698 seconds
Time After: 0.09713 seconds
Time Before: 0.11996 seconds
Time After: 0.12120 seconds
Time Before: 0.12946 seconds
Time After: 0.12963 seconds
Time Before: 0.13194 seconds
Time After: 0.13342 seconds
UPDATE session SET lastactivity = 1785276269, location = '/forums/private.php?do=newpm&explain=1&u=102221', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.15578 seconds
Time After: 0.15619 seconds
