Time Before: 0.00157 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00252 seconds
Time Before: 0.00275 seconds
Time After: 0.00290 seconds
Time Before: 0.00360 seconds
Time After: 0.00628 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00296 seconds
Time After: 0.00982 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01195 seconds
Time After: 0.01234 seconds
Time Before: 0.01520 seconds
Time After: 0.01643 seconds
Time Before: 0.01120 seconds
Time After: 0.01665 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02365 seconds
Time After: 0.02380 seconds
Time Before: 0.02578 seconds
Time After: 0.02704 seconds
Time Before: 0.03000 seconds
Time After: 0.03016 seconds
Time Before: 0.03227 seconds
Time After: 0.03373 seconds
UPDATE session SET lastactivity = 1785328543, location = '/forums/private.php?do=newpm&explain=1&u=102222', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04648 seconds
Time After: 0.04677 seconds
