Time Before: 0.02602 seconds
Time After: 0.02751 seconds
Time Taken: 0.00150 seconds
Time Before: 0.02763 seconds
Time After: 0.02807 seconds
Time Before: 0.02832 seconds
Time After: 0.02843 seconds
Time Before: 0.02913 seconds
Time After: 0.03177 seconds
Time Taken: 0.00264 seconds
Time Before: 0.02852 seconds
Time After: 0.03607 seconds
Time Taken: 0.00756 seconds
Time Before: 0.04493 seconds
Time After: 0.04533 seconds
Time Before: 0.04736 seconds
Time After: 0.04850 seconds
Time Taken: 0.00115 seconds
Time Before: 0.04421 seconds
Time After: 0.04868 seconds
Time Taken: 0.00447 seconds
Time Before: 0.07953 seconds
Time After: 0.07968 seconds
Time Before: 0.09784 seconds
Time After: 0.09908 seconds
Time Before: 0.11113 seconds
Time After: 0.11127 seconds
Time Before: 0.11340 seconds
Time After: 0.11480 seconds
Time Taken: 0.00139 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102228' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.13434 seconds
Time After: 0.13466 seconds
