Time Before: 0.00785 seconds
Time After: 0.01190 seconds
Time Taken: 0.00406 seconds
Time Before: 0.01198 seconds
Time After: 0.01248 seconds
Time Before: 0.01274 seconds
Time After: 0.01299 seconds
Time Before: 0.01377 seconds
Time After: 0.01602 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01306 seconds
Time After: 0.02045 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02466 seconds
Time After: 0.02506 seconds
Time Before: 0.02776 seconds
Time After: 0.02897 seconds
Time Before: 0.02396 seconds
Time After: 0.02924 seconds
Time Taken: 0.00529 seconds
Time Before: 0.04390 seconds
Time After: 0.04420 seconds
Time Before: 0.05459 seconds
Time After: 0.05584 seconds
Time Before: 0.06334 seconds
Time After: 0.06353 seconds
Time Before: 0.06663 seconds
Time After: 0.06812 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102231' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.08677 seconds
Time After: 0.20650 seconds
Time Taken: 0.11973 seconds
