Time Before: 0.00558 seconds
Time After: 0.00751 seconds
Time Taken: 0.00194 seconds
Time Before: 0.00762 seconds
Time After: 0.00805 seconds
Time Before: 0.00825 seconds
Time After: 0.00843 seconds
Time Before: 0.00920 seconds
Time After: 0.01160 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00850 seconds
Time After: 0.01645 seconds
Time Taken: 0.00794 seconds
Time Before: 0.02089 seconds
Time After: 0.02129 seconds
Time Before: 0.02403 seconds
Time After: 0.02524 seconds
Time Before: 0.02014 seconds
Time After: 0.02552 seconds
Time Taken: 0.00538 seconds
Time Before: 0.04819 seconds
Time After: 0.04834 seconds
Time Before: 0.05466 seconds
Time After: 0.05594 seconds
End call of global.php: 0.058135032653809
Time Before: 0.06128 seconds
Time After: 0.06142 seconds
Time Before: 0.06433 seconds
Time After: 0.06596 seconds
Time Taken: 0.00163 seconds
SET lastactivity = 1783145058, location = '/forums/private.php?do=newpm&explain=1&u=102243', badlocation = 1
Time Before: 0.08579 seconds
Time After: 0.08607 seconds
Page generated in 0.084387063980103 seconds with 9 queries, spending 0.008075475692749 doing MySQL queries and 0.076311588287354 doing PHP things.
