Time Before: 0.02974 seconds
Time After: 0.03882 seconds
Time Taken: 0.00908 seconds
Time Before: 0.03895 seconds
Time After: 0.03945 seconds
Time Before: 0.03994 seconds
Time After: 0.04007 seconds
Time Before: 0.04094 seconds
Time After: 0.04365 seconds
Time Taken: 0.00272 seconds
Time Before: 0.04015 seconds
Time After: 0.04928 seconds
Time Taken: 0.00913 seconds
Time Before: 0.05880 seconds
Time After: 0.05901 seconds
Time Before: 0.06178 seconds
Time After: 0.06310 seconds
Time Taken: 0.00132 seconds
Time Before: 0.05796 seconds
Time After: 0.06336 seconds
Time Taken: 0.00540 seconds
Time Before: 0.10507 seconds
Time After: 0.10527 seconds
Time Before: 0.12374 seconds
Time After: 0.12519 seconds
Time Before: 0.13906 seconds
Time After: 0.13926 seconds
Time Before: 0.14194 seconds
Time After: 0.14346 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1782850374, location = '/forums/private.php?do=newpm&explain=1&u=102245', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.16206 seconds
Time After: 0.16238 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
