Time Before: 0.00159 seconds
Time After: 0.00214 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00221 seconds
Time After: 0.00263 seconds
Time Before: 0.00284 seconds
Time After: 0.00295 seconds
Time Before: 0.00365 seconds
Time After: 0.00645 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00300 seconds
Time After: 0.00980 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01154 seconds
Time After: 0.01189 seconds
Time Before: 0.01451 seconds
Time After: 0.01572 seconds
Time Before: 0.01096 seconds
Time After: 0.01595 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02092 seconds
Time After: 0.02111 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:5:\"7.90,\";s:9:\"lastcheck\";i:1788907563;}', 1)Time Before: 0.02669 seconds
Time After: 0.02720 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.02947 seconds
Time After: 0.03075 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.03413 seconds
Time After: 0.03432 seconds
Memory Before: 4,164.359 KB
Memory After: 4,164.789 KB
Time Before: 0.03639 seconds
Time After: 0.03783 seconds
Memory Before: 4,446.148 KB
Memory After: 4,447.836 KB
UPDATE session SET lastactivity = 1788907563, location = '/forums/private.php?do=newpm&explain=1&u=102267' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05070 seconds
Time After: 0.05096 seconds
Memory Before: 4,919.797 KB
Memory After: 4,920.023 KB
