Time Before: 0.00149 seconds
Time After: 0.00203 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00210 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00291 seconds
Time Before: 0.00369 seconds
Time After: 0.00603 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00296 seconds
Time After: 0.00938 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01108 seconds
Time After: 0.01149 seconds
Time Before: 0.01432 seconds
Time After: 0.01557 seconds
Time Before: 0.01050 seconds
Time After: 0.01574 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02075 seconds
Time After: 0.02100 seconds
Time Before: 0.02279 seconds
Time After: 0.02407 seconds
Time Before: 0.02715 seconds
Time After: 0.02739 seconds
Time Before: 0.02951 seconds
Time After: 0.03099 seconds
UPDATE session SET lastactivity = 1776878905, location = '/forums/private.php?do=newpm&explain=1&u=102275' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04382 seconds
Time After: 0.04427 seconds
