Time Before: 0.01205 seconds
Time After: 0.01679 seconds
Time Taken: 0.00474 seconds
Time Before: 0.01690 seconds
Time After: 0.01730 seconds
Time Before: 0.01752 seconds
Time After: 0.01765 seconds
Time Before: 0.01841 seconds
Time After: 0.02045 seconds
Time Taken: 0.00204 seconds
Time Before: 0.01770 seconds
Time After: 0.02459 seconds
Time Taken: 0.00689 seconds
Time Before: 0.02921 seconds
Time After: 0.02963 seconds
Time Before: 0.03119 seconds
Time After: 0.03238 seconds
Time Before: 0.02852 seconds
Time After: 0.03258 seconds
Time Taken: 0.00406 seconds
Time Before: 0.04873 seconds
Time After: 0.04886 seconds
Time Before: 0.05728 seconds
Time After: 0.05854 seconds
Time Before: 0.06563 seconds
Time After: 0.06578 seconds
Time Before: 0.06823 seconds
Time After: 0.06967 seconds
UPDATE session SET lastactivity = 1785368996, location = '/forums/private.php?do=newpm&explain=1&u=102279' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08741 seconds
Time After: 0.08770 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
