Time Before: 0.01638 seconds
Time After: 0.02030 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02041 seconds
Time After: 0.02213 seconds
Time Taken: 0.00172 seconds
Time Before: 0.02298 seconds
Time After: 0.02314 seconds
Time Before: 0.02390 seconds
Time After: 0.02668 seconds
Time Taken: 0.00279 seconds
Time Before: 0.02321 seconds
Time After: 0.03088 seconds
Time Taken: 0.00767 seconds
Time Before: 0.03497 seconds
Time After: 0.03516 seconds
Time Before: 0.03781 seconds
Time After: 0.03903 seconds
Time Before: 0.03440 seconds
Time After: 0.03933 seconds
Time Taken: 0.00492 seconds
Time Before: 0.07265 seconds
Time After: 0.07307 seconds
Time Before: 0.08479 seconds
Time After: 0.08603 seconds
Time Before: 0.09332 seconds
Time After: 0.09351 seconds
Time Before: 0.09597 seconds
Time After: 0.09743 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102289', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.11504 seconds
Time After: 0.11535 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
