Time Before: 0.00256 seconds
Time After: 0.00343 seconds
Time Taken: 0.00088 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00351 seconds
Time After: 0.00401 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00426 seconds
Time After: 0.00443 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00515 seconds
Time After: 0.00811 seconds
Time Taken: 0.00296 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00449 seconds
Time After: 0.01163 seconds
Time Taken: 0.00714 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01356 seconds
Time After: 0.01394 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01632 seconds
Time After: 0.01765 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01283 seconds
Time After: 0.01785 seconds
Time Taken: 0.00502 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02453 seconds
Time After: 0.02467 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03422 seconds
Time After: 0.03551 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04553 seconds
Time After: 0.04572 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04801 seconds
Time After: 0.04947 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773148453, location = '/forums/private.php?do=newpm&explain=1&u=102294', badlocation = 1 WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.06644 seconds
Time After: 0.06679 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
