Time Before: 0.02012 seconds
Time After: 0.02693 seconds
Time Taken: 0.00680 seconds
Time Before: 0.02700 seconds
Time After: 0.02760 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02787 seconds
Time After: 0.02802 seconds
Time Before: 0.02868 seconds
Time After: 0.03114 seconds
Time Taken: 0.00246 seconds
Time Before: 0.02807 seconds
Time After: 0.03552 seconds
Time Taken: 0.00745 seconds
Time Before: 0.04411 seconds
Time After: 0.04455 seconds
Time Before: 0.04698 seconds
Time After: 0.04822 seconds
Time Before: 0.04338 seconds
Time After: 0.04844 seconds
Time Taken: 0.00506 seconds
Time Before: 0.07715 seconds
Time After: 0.07732 seconds
Time Before: 0.09578 seconds
Time After: 0.09705 seconds
Time Before: 0.10751 seconds
Time After: 0.10771 seconds
Time Before: 0.10988 seconds
Time After: 0.11135 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=102310', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.12970 seconds
Time After: 0.13002 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
