Time Before: 0.02865 seconds
Time After: 0.03766 seconds
Time Taken: 0.00901 seconds
Time Before: 0.03778 seconds
Time After: 0.03819 seconds
Time Before: 0.03842 seconds
Time After: 0.03854 seconds
Time Before: 0.03942 seconds
Time After: 0.04185 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03861 seconds
Time After: 0.04585 seconds
Time Taken: 0.00723 seconds
Time Before: 0.05604 seconds
Time After: 0.05645 seconds
Time Before: 0.05942 seconds
Time After: 0.06060 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05536 seconds
Time After: 0.06082 seconds
Time Taken: 0.00546 seconds
Time Before: 0.10454 seconds
Time After: 0.10465 seconds
Time Before: 0.20237 seconds
Time After: 0.20367 seconds
End call of global.php: 0.20651793479919
Time Before: 0.21967 seconds
Time After: 0.21985 seconds
Time Before: 0.22250 seconds
Time After: 0.22458 seconds
Time Taken: 0.00207 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=102314', badlocation = 1
Time Before: 0.24693 seconds
Time After: 0.24725 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.24584293365479 seconds with 9 queries, spending 0.0085299015045166 doing MySQL queries and 0.23731303215027 doing PHP things.
